need help pulling tranny
tryn to take my block out but cannot get the block separated from the trany! everything is off and out of the way and will come apart a lil bit but not all the way. any ideas?
Did you pull the clutch fork out? Remove the clutch cylinder pull the fork out a little (It will fall into the housing) If you do not do this you will not be able to separate Tran from engine. Just pull it out some and it will stay in housing until they are separated.
all the bolts are out there is nothin left to be takn out. we have gotn it apart a good ways and it just seems like there is somthin holding it up and its pissn me off.! im about to just pull it all out..lol
