In need of starting help
Old Sep 2, 2012 | 06:02 PM
frankdatank91's Avatar
Default In need of starting help
First bought my s2000 about a month ago. 140xxx miles. It's done this three times to me now. The first two times it refused to start for only about 20 seconds. I turn the key on everything lights up like normal. I press the clutch and push start button. The ABS light stays lit and I can hear a little click/buzz while I'm holding the button. Headlights work fine and top goes up/down. The third time it took about 5 minutes to start. I pressed the gas about 10 times and turned a few electronics on for testing then finally I held the button/gas pedal and slowly depressed the clutch. It started.
I havent tested the battery yet or alt. Anyone have this problem?
Thanks everyone. I'm not too mechanically inclined when it comes to diagnosing lol
Old Sep 3, 2012 | 08:49 AM
RacerXI's Avatar
Have your battery checked by a parts store?
Old Sep 8, 2012 | 09:48 PM
today I had my battery checked along with the alt/starter. AZ said they are all perfect. So I guess now it's time for a tune up, hopefully it doesn't do it again.
Old Sep 9, 2012 | 04:44 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
First off:
Is the car having a problem cranking, or is it cranking fine but not firing up?
Old Sep 12, 2012 | 05:09 PM
doesnt crank at all sometimes. full power to everything else. I'm just gonna change the starter to avoid being stranded lol
Old Sep 12, 2012 | 05:50 PM
wiyo85's Avatar
Im thinking of doing the same. I'm having a similiar problem. i press to start and i just get a click. its been doing it random but now i might press to start about four times and won't start. everything works with key on no battery light on. i would wait a sec or two then try again but with a slow and steady press and voom my car starts. mind its an 04' 12xxxx miles. i dont know if it could be the start button or soleniod or starter.
Old Sep 13, 2012 | 05:16 AM
Billman250's Avatar
Top Answer: 1
Replacing the starter is a bad idea and is only guessing.
There are plenty of other issues that can cause a no crank. O the S2000, the starter is the last of them.
Old Sep 13, 2012 | 09:27 AM
rxrotorless7's Avatar
If it doesn't crank when you hit the start button, I would check the clutch pedal switch...
my02s2k1
Sep 15, 2016 03:58 PM
Spartikus
Aug 21, 2012 02:43 PM
s2000.to
Oct 24, 2011 11:21 AM
greys2k
May 15, 2005 03:12 PM
jss2k
Jan 30, 2005 10:13 AM
