new intake = new problem
Old Mar 27, 2007 | 12:38 PM
Sleshy's Avatar
Default new intake = new problem
hey guys,
i just installed a k&n 63-3514 on my 06 s2k. i followed all the directions and have done many installations like this before. but now my malfunction light is on. there are no hoses to screw up since the 06's dont have the air injecting pump, which im pretty sure means no air control valve vacuum and air control solenoid vacuum. is there anything i could have screwed up. i drilled the hole correctly for the air temp sensor. any suggestions????
thanx a lot,
slesh
Old Mar 27, 2007 | 12:52 PM
plokivos's Avatar
what code is it?
go get your code pulled at pep boys.
rest of the comments are just guesses that rely on you driving to pull that code.
Old Mar 27, 2007 | 12:57 PM
Sleshy's Avatar
code for what? does it sound like i installed it right?
Old Mar 27, 2007 | 01:02 PM
vtec9's Avatar
You mean your Check Engine Light is on? (its a little light shaped like an engine). If so, go to pep boys, autozone, etc and they will hook up a scanner and pull the code for you for free. Then you can determine what the problem is.
Old Mar 27, 2007 | 03:31 PM
Sleshy's Avatar
i went to autozone and they plugged into my car. it said the apc aipc something like that was too high. but i reset my battery and the malfunction light went away. my car seems like its running fine.
Old Mar 27, 2007 | 03:37 PM
shotiable's Avatar
sounds good! hope you enjoy your k&n
Old Mar 27, 2007 | 03:45 PM
doheboy6's Avatar
For future reference: https://www.s2ki.com/forums/index.php?showtopic=378792
S2KCHRIS305
Dec 4, 2016 07:51 AM
project*stealth
May 6, 2013 08:36 PM
EnvyMyS2K
Sep 3, 2012 11:55 AM
Fatcow21
Sep 12, 2008 07:52 AM
typer0085
Jun 8, 2004 05:52 AM
