New MAP sensor and now my car won't work
Old Jun 24, 2016 | 05:37 PM
AlexSobe614's Avatar
Default New MAP sensor and now my car won't work
Hey guys, I just installed a new map sensor and every time I turn the car on it'll start but immediately stall afterwords. If I put the old sensor on it starts right up and runs fine though.
Old Jun 24, 2016 | 06:54 PM
Chuck S's Avatar
Why did you replace it? Seems it was working fine.
-- Chuck
Old Jun 24, 2016 | 10:19 PM
-- Chuck
Car was having pretty bad idle problems. Was hoping the new one would fix it
Old Jun 25, 2016 | 04:27 PM
freetors's Avatar
If you got it at a parts store it might be garbage. However, you could try disconnecting the battery to force the ECU to reset. It probably needs to relearn the new sensor.
Old Jun 25, 2016 | 04:38 PM
zeroptzero's Avatar
Is the small o-ring in place under the map sensor ?
Old Jun 26, 2016 | 10:52 AM
Forziii's Avatar
When I installed a new MAP sensor I didn't have to do any type of resets to the ECU (although, I did a few days after for other reasons, it ran fine right after installing without disconnecting battery or resetting).
Old Jun 27, 2016 | 07:17 AM
King Tut's Avatar
Did you replace it with an identical OEM sensor?
Old Jul 5, 2016 | 04:55 PM
Jones Auto's Avatar
If you purchased a non oem sensor, take it back, their garbage. Standard Products are the worst, regardless of the part used. Doesn't matter what type of car your using them on. The aftermarket parts just aren't calibrated correctly
Old Jul 11, 2016 | 05:21 PM
I sent it back and just bought an OEM one. Screw that lol
amdaman
May 20, 2015 01:35 AM
veehexx
Aug 8, 2009 03:32 AM
jason4207
Sep 2, 2005 11:10 AM
JohnE
Aug 10, 2005 08:20 AM
thrackley
Aug 12, 2004 10:00 AM
