New TCT leaking
Did the TCT go all the way into the engine block with a little push with your fingers -- not by pulling it in with the bolts?
Didn't you just ask Billman about his TCT on Monday -- and went ahead and bought the Ballade anyway? Installation failed on this one too. You're #3 this week
-- Chuck
-- Chuck
If you don't have any problems with the OEM tensioner, like rattles from a loose chain then do not install a Ballade tensioner.
On a good tight chain you are most likely going to get it over tightened with aftermarket tensioners like Ballade, this is not good at all.
quick question, can a failed tct stop you from hitting vtech ? i’ve had a tct problem for a while now and i’m about to replace it with a billman, i know for sure the rattling will stop but what i don’t know is if that’ll fix my vtech. is that a different problem that doesn’t involve the tct ? or can you still hit vtech with a failed tct ? if so i think i might have another problem *knock on wood*
Dark Regent
Jan 19, 2019 11:17 PM
