No gear will lock anymore...
Old Sep 18, 2009 | 12:42 PM
Qiuness's Avatar
Default No gear will lock anymore...
Hi...
today is a shitty day!
i was driving in the city with my newly installed ACT clutch and flywheel. i have around 500miles with that clutch. anyway .. i changed first.. then second and i did a miss shift (it squeetched a little, but it locked the gear)
After that i tried 3rd and nothing. Then no GEAR locked!
symptoms:
- With the motor off 1st 3rd and 4th lock
- if i start the engine after i get in gear, it stalls
- Clutch is still hard, but however i push it it wont let me get in gear
My questions are:
1. what could it bee
2. could the guys who mounted the clutch be responsible for whatever happened?
Thanks a lot!
Old Sep 18, 2009 | 01:01 PM
ahrmike's Avatar
it sounds like clutch master/slave is not properly bled -or- the slave piston isnt resting properly on the clutch fork.
Old Sep 18, 2009 | 01:47 PM
Fast Jack's Avatar
Have it towed to the shop that did the work,500 miles ? = they were not diligent in their work,most likely.
Old Sep 21, 2009 | 03:42 AM
Qiuness's Avatar
Thanks for the reply's...
Any tips that i should give them?
Their gonna take the car apart today...but i doubt they`ll tell me what really was wrong..
Old Sep 22, 2009 | 10:18 AM
Qiuness's Avatar
described the issue again... since i posted on a different site as well
i need some advice from you car tech freaks... since imo this should not happen.
Bought a new clutch since the old one was burned out.
I bought a ACT 6 Puck heavy duty clutch with flywheel and all.
after ~500 miles i was driving in the city and i reversed, and then @5k rpm spun the wheels in first gear, changed second (miss shifted), but eventually it connected, and when i tried to change to 3rd, all the gears went dead, and i could not change into any other gear.
Today the car was opened up and the flywheel was glued to the pressure plate. :-/
so basically how on earth can the flywheel get to ~2000 degrees and stick like ****ing super glue?! Even if i spun the wheels, i released the clutch fully so the flywheel was not heating up due to friction?
Has anyone seen this kinda clutch bonding?!
Old Sep 23, 2009 | 12:28 AM
Fast Jack's Avatar
Man dats some crazy shyt.I have act clutch/pp but not the 6 puck.Be curious to the answer for this one.
Old Sep 23, 2009 | 12:42 AM
S2Kmonkee's Avatar
so your clutch was basically engagement the whole time ?
Old Sep 23, 2009 | 08:33 AM
schefdeh5's Avatar
I think it may be your shifter....when you shift, there's this lever....a nut is used for that lever to be tightened...if that's loose...your shifting could be "loose" and tho your shifter might move, you aren't putting it into any gears b/c the nut is too loose..
Does your shifting feel "loose"?
Rio Sunset
Mar 6, 2015 03:21 PM
DillonS2000
Jun 17, 2014 07:58 AM
CR22
Sep 16, 2009 10:48 PM
skem
Sep 12, 2009 09:02 PM
Brutewes
Jul 3, 2003 09:33 PM
