no vtec + oil light
hey guys/girls, I sold my S a few months ago and it turns out my boss bought the car off the guy i sold it to. The rear end went (again), After rebuilding that (again) The oil light is on ONLY at idle if you give it gas to about 1100 rpm the light goes out. Also Vtec isn't engaging (but it will still rev to 9k)
The owner says he was doing 131mph at 8k in 5th gear, pushed it the clutch after letting off and it stalled and the CEL and oil light came on. Havent checked the code yet but any help would be appreciated, Thanks
Yeah with it flickering and only being on at very low rpm it seemed like an electrical issue.
The rear diff temp light in the GFs STi would flicker only at certain points as well. We checked the fluid and all was good. Turns out we just needed to clean and tightern the little sensor on the diff housing. ;-)
Glad you caught it before he trashed(auctioned) a nice car.
If the light is on at low RPM, it's probably because there is less pressure at idle. If there is a faulty pump, or shot bearing clearance, it shows up most noticeably at idle. You need an oil pressure gauge hooked to the engine. Pressurize the oil switch off the car to the correct pressure and see how it reacts. Stop guessing.
