Yet another Vtec Problem
Old Dec 23, 2006 | 12:00 PM
H-twnBerlina's Avatar
Default Yet another Vtec Problem
Today I was driving around town and this Mazdaspeed 6 comes up behind me really fast, so I rev-match down shift into Vtec to go after him but my Vtec stutters and won't work and a CEL comes on. So I reset the ECU and go for a run. Vtec works for 1st and 2nd,then I slow down and drop it into Vtec again and it stutters and doesn't work. The car is properly heated. I think the problem is that I may have too much oil. Because my oil light flickered and I checked my oil level and it is at or maybe even a little but above the H. So my question is what do you guys think I should do?
Old Dec 23, 2006 | 12:26 PM
FISH22's Avatar
hmmm....my guess would be the oil pump, maybe its shot, or cant make much pressure anymore. considering your oil light flickered, i really think it only comes on when oil pressure is low. you said you had the oil just over the H mark, thats actually okay, it wouldnt cause something like this. good luck!!!
Old Dec 23, 2006 | 03:32 PM
Slows2k's Avatar
Oil light on = Low oil pressure.
If the crankcase is full of oil and the light came on, chances are the engine has some pretty serious wear. If the oil pump was broken you'd have no oil pressure all the time.
Old Dec 23, 2006 | 09:19 PM
I don't think wear is the problem being that the car has only 60,000mi on it. It may be a spark plug problem, being that I don't know when the last time they where changed was. I just did a MAP whack and took it on a quick run and that seemed to work but I don't think that will stay like that. I am going to change the spark plugs, and get the code read ASAP.
Old Dec 26, 2006 | 10:51 AM
Update: I definitely think its an oil problem. The engine sounds really rough. I think the oil pump is starting to kick the bucket. Im going to put some new oil in it and drive it to the dealership. If you have any other ideas I would be glad to hear them.
Old Dec 26, 2006 | 11:28 AM
brimstone's Avatar
Your car threw a CEL, you've been thinking its an oil problem, the engine runs rough, and you're still driving it to the dealership?
I wouldn't touch the car with a 10 foot pole without getting the code read, especially if the engine is running rough. You might be damaging your goods with every single rotation. Stop driving it, and get it towed if possible if its as serious as you lead us to believe.
Old Dec 26, 2006 | 01:50 PM
Slows2k's Avatar
Tow the car. Stop driving it.
Old Dec 26, 2006 | 02:12 PM
s2krey's Avatar
any cel that comes on STOP DRIVING!
S2k_223
Apr 28, 2013 05:54 PM
pghs2kid
Apr 4, 2012 06:40 PM
FastestS2K
Sep 20, 2005 06:08 AM
Iggy_Type_R
Aug 6, 2002 08:59 PM
