Noise on decel
Hey guys.
Im not sure if this is normal on a MY04 or not but when I let off the gas around 4k-5k rpm I start to here a chatter( with the clutch engaged). Once I get down around 2k i can no longer here it. What do you all think FWIW its a stock clutch flywheel combo.
Yea it's normal.Like many have said before, our cars have many advanced working mec. systems.It is not going to sound like moms Lexus RX.Are you actually having any mec. problems when driving the car?If so, take it to the Honda dealer.They will take a look.
its fine. i tend to grease my transmission spline where the throwout bearing moves back and forth on.. you can get to it by removing the slave cylinder and some lucas high temp grease and coat hanger... usually last's an oil change or 2 since you cant get it directly were you want it unless you remove the transmission..
