Ohm range of fuel tank level indicator?
Old Nov 11, 2004 | 05:50 AM
cjb80's Avatar
Default Ohm range of fuel tank level indicator?
Anyone know the Ohm range of fuel tank level indicator?
Thanks
Chris
Old Nov 11, 2004 | 07:06 AM
xviper's Avatar
Float Position / Resistance (ohms) / Height (mm)
F / 11 - 13 / 82.9
1/2 / 52 - 58 / 154.2
LOW / 114.4 - 120.4 / 215.5
E / 130 - 132 / 222.8
(Measured between the No. 1 and No. 2 terminal side of male terminals.)
Old Nov 11, 2004 | 07:30 AM
cjb80's Avatar
Wow, I didn't actually expect an answer like this! Awesome! I don't know that much about electronics beyond hooking up guages, and simple sensors. What does "Measured between the No. 1 and No. 2 terminal side of male terminals" mean exactly?
There are 4 wires going to the fuel pump, I assume that one is power, one is ground, and I assume the last two are related to the fuel level indicator, right? Have you messed around with this clip? Does the manual identify which wires are which?
I installed a fuel cell in my car, and I would like to figure out a way to get the fuel level indicator to work with stock. I think it is a 0-90 ohm sensor.. so when it's empty it would probably show 1/4 of fuel left or something.
Thanks!!
Chris
Old Nov 11, 2004 | 08:15 AM
xviper's Avatar
Yes, there are 4 wires going "TO" the pump, but on the pump side of the harness (male), there should be 5 pins. I don't know what the fifth pin is for. I haven't looked that closely, only to separate the harness when putting in the Vortech fuel pump. On the 4 pin side, PIN 1 and 2 are the BLK and YEL/BLK wires. You want to hook up the ohmeter to these corresponding pins on the male side (on the pump).
If you look head-on into the open harness on the pump side, the little "out-dent" should be on top, with the 2 angled sides next to the flat bottom. In this configuration, PIN 1 and 2 are the top left pin and the top middle pin. It is these two that you take the reading. Good luck.
Old Nov 11, 2004 | 08:21 AM
cjb80's Avatar
OK, next question is that I have a 0-90ohm fuel level output from the fuel cell. My buddy tells me that I need to get an electrical engineer to figure out how to convert 0-90 ohm to a 0-130 ohm range.. thoughts?
The other two wires must be the ground and power to the fuel pump, right?
Thanks again!
Chris
Old Nov 11, 2004 | 08:30 AM
xviper's Avatar
Now you're into uncharted territory for me. "Modifry" would be your man for this sort of thing.
As for the other wires, I believe you are correct in your statement.
staylor725
Jun 25, 2017 04:17 AM
lopez14
Mar 21, 2013 08:00 AM
Spec_Ops2087
May 18, 2010 01:58 PM
P5744D
Feb 10, 2008 11:33 AM
GDM S2K
Mar 15, 2006 01:56 PM
