Oil light
Old Jul 11, 2012 | 06:00 AM
skyteg's Avatar
Default Oil light
Hi, so i read alot here on the oil light coming on at idle after the engine is hot and that helped me to identify that it was a bearing on the crank that was the problem. Got the bearings on the crank polished, change all the gaskets, the pistons the rings, basically got the block rebuilt. Now the oil light still comes on at idle... Kinda lost, and wondering if with a rebuilt block, it's harmfull or what could i do??
Thanks
Old Jul 11, 2012 | 09:31 AM
apme123's Avatar
time to look for a used motor.
Old Jul 11, 2012 | 09:34 AM
iDomN8U's Avatar
Thanks
hook up a oil pressure reader and rely back the numbers (include year of car and any modifcations)
did you check your main journal?
Old Jul 11, 2012 | 09:36 AM
SLracer's Avatar
What did the engine look like when you tore it apart? Did you plastigauge all the bearings both the old and new? Were any of your bearings spun? Usually an oil light on these cars suggests you have already spun a bearing.
Old Jul 11, 2012 | 10:15 AM
skyteg's Avatar
Yes the bearing was definetly spun. I had metal and copper shavings in my oil, so that's why the shop had the engine rebuilt. But even though the bearings on the crankshaft have been repolished it still comes on.
Old Jul 11, 2012 | 10:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Somewhere in the engine, you have an excessive oil clearance.
Sad to say the rebuild was a failure. Any of the mains, rod journals, top end or thrust surface can affect the oil pressure.
Old Jul 11, 2012 | 12:41 PM
skyteg's Avatar
alright thanks alot billman! guess ill look for another motor..
climhazzard
Jul 5, 2012 09:09 AM
Owen_1987
Oct 16, 2010 02:19 AM
13darkknight
Jan 15, 2008 04:49 AM
onfire01
Mar 1, 2007 07:30 AM
BlitzSRM
May 3, 2004 10:52 AM
