omnipower master cylinder
Old May 11, 2013 | 04:45 PM
s2kneub's Avatar
Default omnipower master cylinder
hello
so i installed this beast with some rather disconcerting results as it's now reasonably difficult to get it into gear when cold or stopped.. is this normal or is there some sort of adjustment that needs to be done? keep in mind, i bled the system properly, nothing's leaking, and the reservoir is topped off.
it's the quickclutch master cylinder btw
Old May 11, 2013 | 08:30 PM
drobinson1692's Avatar
did you adjust the freeplay? you might have too much
Old May 11, 2013 | 09:44 PM
s2kneub's Avatar
i didnt adjust the free play at all.. would i want to adjust it in towards the firewall or out?
Old May 12, 2013 | 04:41 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
My experience with this part has been horrible and I would not recommend it to anyone.
Old May 12, 2013 | 05:13 AM
s2kneub's Avatar
what havent you liked about it?
Old May 12, 2013 | 07:02 AM
PureFunction's Avatar
You probably need more pedal throw. it should be adjusted so there is a small amount of free play on the pedal before it starts to push on the rod for the cmc.
i know its not really relevant to this car but.... i had one on my 06 civic si. Pedal throw was so hard it cracked my fire wall and was about to push through. Needless to say everyone uses the cmc from the em1 now.
Old May 12, 2013 | 07:55 AM
s2kneub's Avatar
lol holy crap. so, i didnt adjust the free play because it didnt seem like it would help as the problem was with forward motion of the arm into the cylinder, however, i did remove the bumper on the firewall that stopped the pedal arm from actually making contact with the firewall. now it shifts properly.
Old May 14, 2013 | 10:58 AM
06ap2_89's Avatar
any early thoughts on the CMC? like it, unsure, don't like it?
Saki GT
Jan 28, 2022 04:57 AM
panda25
Apr 20, 2017 12:40 AM
HPIracing
Jan 29, 2011 08:49 AM
tomkbucks
Mar 10, 2010 11:40 AM
