over revved..
Back when I first got the car about 3years ago. I overreved from 3rd to 2nd for about 1-2sec while running threw the gears getting on the freeway.
To present, no problems yet cept. for a slipping clutch. I'm sure your good since its been quite alot of miles.
Originally Posted by Neutered Sputniks,Nov 7 2008, 09:55 AM
Because the overrev a year prior is the only thing that could've caused the warpage?
nothing else happened in between.
Originally Posted by ans2k,Nov 8 2008, 01:58 AM
when and how much does a compression test cost?
how much does a compression test cost? Probably get charged an hour labor, so depends on where you take it.
Originally Posted by jyeung528,Nov 7 2008, 09:33 AM
i mis-shifted and had good compression numbers. i replaced the retainers for peace of mind.
a couple years later...i had bad compression, warped valve guides, warped valve face...
i would change the retainers for peace of mind and continually check the compression.
don't think you're fine forever.
aceprince
Dec 31, 2002 09:35 PM
