overtorqued?
Old 04-24-2007, 10:16 PM
mgebers's Avatar
Default overtorqued?
so i did a tranny fluid change tonight and replaced with some GM synchromesh (which works swimmingly - thank you everyone)
but I'm not much of a genious and I think i overtorqued the drain bolt, the crush washer got a little bent out of shape, but didnt crack. there is no leakage so far and everything is running fabulous. But i wanted to know if there was any issues that could evolve from not properly torqueing either of the two bolts involved in the tranny fluid change???
Old 04-24-2007, 10:25 PM
s2k dre's Avatar
just snug it a little tight. maybe like 30ft lbs
Old 04-25-2007, 05:36 AM
tinkfist's Avatar
If you overtorqued those bolts, or any bolts for that matter, you run the risk of stripping the threads in the holes. You would know if it is stripped if you can only tighten it a certain amount before it becomes loose again. This does not sound like the case, so you're fine. Be careful in the future
Old 04-25-2007, 09:00 AM
vtec9's Avatar
I overtorqued the oil drain bolt on my block once.. I wasn't paying attention, the torque wrench wasn't tightened down, and I probably hit it up 45-50ft-lbs. Haven't had a problem.
Old 04-25-2007, 09:57 AM
jyeung528's Avatar
what do you mean by bent out of shape?
that doesn't sound good...
Old 04-25-2007, 01:15 PM
mgebers's Avatar
it got a little mishapen, as in not perfectly round. I took it back off to make sure i didnt strip anything and it came off fine, and there were no cracks, and its still holding a seal, i just assume next time i change it i'll need a new one, just to be careful. Nothing seems to be wrong right now, everything is working great. I was just making sure that i wasnt going to have any permanent damage to anything
Old 04-25-2007, 08:18 PM
steven975's Avatar
that washer is there for a reason. It seems to have saved the threads.
Old 04-25-2007, 11:30 PM
RACER's Avatar
Tighten it till it strips, then back it off a 1/4 turn.
Old 04-26-2007, 08:33 AM
mxt_77's Avatar
That's just wrong.
Old 04-26-2007, 11:16 AM
00CivicSi's Avatar
Honda recommends changing out the crush washers each time anyway. However, many people don't and have no problems. If it's not leaking, it's fine. If it's deformed, I'd replace it next time.
AZS2KDancer
12-28-2017 09:27 AM
daygolove
San Diego S2000 Owners
09-18-2007 06:25 PM
daygolove
09-18-2007 05:53 PM
vtec9
12-03-2006 02:26 PM
Jsmply
11-22-2006 03:29 PM
Quick Reply: overtorqued?
