P1456 EVAP
Old Oct 21, 2006 | 05:29 PM
s2k619's Avatar
Default P1456 EVAP
I have this code. I do not know what it means. My car is runing like crap after 6krpms. If i go to wot it just rev's as if it was in netural. It does not putter or any thing like that just a loss of power.
Some help please....
Old Oct 21, 2006 | 06:13 PM
spunkysandoval's Avatar
what year do you have?
what mods have you done to possibly induce this concern?
are you sure that is the only code?
Old Oct 21, 2006 | 06:22 PM
the first thing I'd check is my gas cap. Did you possibly leave you gas cap loose for at least two trips? This code sets when a failure is detected by the evap monitor for system leakage on two different drive cycles. You must have some sort of leak in your evap system or the gas cap was simply left of.
Clear the code, tighten your gas cap, and do a quick visual inspection of the fuel tank lines/filler neck/evap vapor tubes.
The monitor does not run every drive cycle. Certain conditions have to be met for the monitor to run, so after you clear the code it may not reappear for some time.
Old Oct 21, 2006 | 09:29 PM
thecbrman's Avatar
gas cap.. i had it on my car a few years back. i changed my gas cap and it went away.
Old Oct 22, 2006 | 01:15 AM
s2k619's Avatar
the only Mod I have 2002 with a v2 cai. Before I had the gas cap prob but a check engine light cam on. This time no light. I wll have to look under my car tommarow and see if any thing is messed up.
dorifito
Mar 9, 2012 08:45 PM
soozookabluS2k
Oct 11, 2011 03:03 PM
freq
Sep 21, 2010 03:41 AM
paul__chen
Mar 30, 2009 08:56 AM
Amer
Feb 3, 2006 09:29 AM
