Passenger window and soft top not working( need help! )
Old Feb 9, 2012 | 06:38 PM
nobita89's Avatar
Default Passenger window and soft top not working( need help! )
Hi guys,
I got an ap1 02 and last week i upgrade my ap1 console to ap2
Since i upgrade havent got chance to drive. So late yesterday, i found the passenger window not working and roof not working.
So i chance back to ap1 console. It also do the same.
Already check the fuse all working perfect.
Please fellas,need help here.
Thanks
Old Feb 9, 2012 | 07:34 PM
JohnsS2000's Avatar
control module for the top if i am not mistaken, the top not working correctly will cause the window issue. it is in the "under the hood" section.. youll have to do some searching though. i have heard of this, not experienced it though
Old Feb 10, 2012 | 04:48 AM
whiteflash's Avatar
You're going to have to remove the console, and play with the connectors by the e-brake likely.
Old Feb 13, 2012 | 02:45 AM
nobita89's Avatar
Hi guys,thanks for the advice but i already try them,still not working.
The mechanic said it might be the ecu,and some said might be the control unit got burn.
But i try to my mate ap1 they worked.
So i may assume the cable or else.
Plz guys need more advice...
Thanks!!!!!
Old Feb 14, 2012 | 08:03 AM
Kermdaddy's Avatar
Moved to UTH
Old Feb 14, 2012 | 10:59 PM
volkdc2's Avatar
I'm having the same issue, however, my top works, but window refuses to go down unless the top button is pressed. Weird, and I'm still trying to find a solution for it.
Old Feb 15, 2012 | 07:01 AM
jsenclosure's Avatar
soft top module. It's an electronic, they go bad
Old Feb 15, 2012 | 07:02 AM
Old Jan 12, 2013 | 04:51 PM
nobita89's Avatar
Thanks guys! got the problem solve!!
Old Aug 25, 2013 | 07:21 AM
HonDaPursuit's Avatar
How?
s2000 tigers
Nov 14, 2025 11:41 PM
AZS2KDancer
May 19, 2015 09:08 PM
perrbox8
May 13, 2009 08:31 PM
xlaox
Mar 6, 2009 03:16 PM
s2kro
Dec 17, 2008 03:14 PM
