planning on getting the jdm f20
Old Jun 17, 2010 | 11:45 AM
chubbys2k's Avatar
Default planning on getting the jdm f20
i am planning on buying another engine since mine is going bad. ive been lookin for motors and i found that the jdm motors are around the same price as the usdm motors.
1. what i want to know is wat is the difference other then the HP and higher compression?
2. will it pass emissions? because the guys at hmotors said all i need to do is use my usdm intake manifold. is that true?
3. can i run the usdm ecu and pass emissions? or do i need the jdm?
4. can i do this and pass it with no problems?
i am from new england and we have 93 octane.
thanks!
Old Jun 17, 2010 | 11:49 AM
240toS2k's Avatar
The USDM ECU is mapped for the lower compression US motor so I would image you'd be running the motor out of tune.
Old Jun 17, 2010 | 11:53 AM
suzuka-blue-s2k's Avatar
I would just avoid it, since its possible it could just cause you more problems than you thought. Way easier and simple to get a USDM engine and drop in.
Old Jun 17, 2010 | 01:13 PM
rob-2's Avatar
Lots of headaches for 15hp. I'd put the time into producing that much power from an USDM motor.
Old Jun 17, 2010 | 01:58 PM
gCHOW's Avatar
im running one with no problems. even passed smog when i got the car.
of course, i bought the car with the JDM motor in it already so i didnt have to deal with the headache of making things work.
Old Jun 17, 2010 | 11:27 PM
H22toF20's Avatar
If you plan on staying N/A and you don't plan on building the motor, then yeah go for it. If you're plan on boosting or building the motor, then just buy a USDM.
Paperboy7777
Apr 10, 2016 12:06 PM
tre3478
Aug 16, 2014 09:22 AM
motoracer90
Aug 7, 2011 06:23 PM
ocd_2k3
Oct 15, 2007 06:13 PM
i</3speedbumps.
Jan 10, 2007 09:13 PM
