po411 question
Old Mar 28, 2015 | 10:01 PM
cosmic_waffle's Avatar
Default po411 question
hey yall. i know this topic has been discussed before and i have done a bit of research but still have a question. so i did the clutch on my car earlier today which required removing the air box. my buddy took the air flow tube (tube that air filter goes into and connects to the intake) off i noticed quite a large tear on the tube where it clamps down the intake mani. i think he may have tried yanking it off with out loosening the worm clamp but i didnt see thus resulting in a tear. we electrical taped it for now but my question is would this tear be the cause of my p0411 code? ive checked vaccum lines and everything seems to be where it should which leads me to believe the tear in the tube is what is causing the code. if anyone could chime in thatd be cool. thanksz
Old Mar 29, 2015 | 07:36 AM
Slowcrash_101's Avatar
Depends, if the tear is near the breather on the intake hose then yes it could throw a p0411. You could have a leak from the breather to the intake tube it would also throw a code.
Old Mar 29, 2015 | 05:03 PM
sam i am's Avatar
In my textbook, DTC P0441 appears to be evaporative emission control system insufficient purge flow.
http://www.obd-codes.com/p0441
Old Mar 29, 2015 | 05:05 PM
sam i am's Avatar
In my textbook, DTC P0441 appears to be an evaporative emission control system insufficient purge flow
awild
Dec 30, 2011 12:52 PM
ravi1987
Feb 22, 2009 05:09 PM
kidxsai
Jul 6, 2006 12:05 PM
mustangkiller01
Aug 18, 2004 09:09 PM
Feezy
Aug 8, 2003 09:33 PM
