Pop/ clunk / click in rear
Old May 27, 2015 | 10:29 PM
ash_dysonS2k's Avatar
Originally Posted by windhund116
Did the car start making this noise after you swapped axles? You have the OEM ones or are they no good?
Has the car been in an accident?
Car hasn't been in an accident, and the noise only started after the new axles were installed along with the R200 differential, OEM ones won't fit anymore because the new diff is wider than the S2k one, I got another set of axles and still makes the same sound
Old May 28, 2015 | 05:32 AM
Slowcrash_101's Avatar
Wheel bearings?
Old May 28, 2015 | 10:48 AM
Chitoki's Avatar
Once you start to hear that noise, its is definitely a sign of the rear axle nut. Im over zealous with these things and would just replace the bearing and hub while at it... last time I had the noise, I pulled the bearing and hub, the hub was worn to shit and the bearing was on its way out.
Old May 28, 2015 | 08:22 PM
I thought wheel bearing noise would only appear whilst turning? Or have I heard wrong? It hasn't happened whilst turning unless I go over a bump at the same time or while reversing off my driveway onto the road as it leaves the kerb I will hear a pop sometimesoon 2.
getting a mechanic to look at it tomorrow see if I can finally kill the problem.
Old May 28, 2015 | 08:42 PM
arsenal's Avatar
Hold the wheel at 12 and 3 and see if there's play
Old Jun 9, 2015 | 03:17 PM
No play at all. Didn't think you could do it that way to check bearings on the car?
Or was I looking for something else? Either way no sound
Old Jun 10, 2015 | 07:35 AM
arsenal's Avatar
Meant 12 and 6, not sure what I was thinking, (tie rods / rack is 9 and 3)
liquid_helix136
Jul 10, 2012 08:17 PM
t0m
Sep 21, 2010 08:09 PM
Lunacy
Mar 1, 2008 03:44 PM
s2kntx
Oct 6, 2007 09:49 AM
radtech
Sep 8, 2006 01:00 PM
