Power Issue
Old Apr 11, 2015 | 07:23 PM
proracer07's Avatar
Default Power Issue
Hey s2ki, I just came back from the dyno, got my car flashed. My tuner told me I wasn't making normal power. I was making 195 Horsepower and 130 torque. I don't know if it's normal. My car is MY07, 109,000, only mods I have is tires, J's racing 70RR, and lowered springs.
Old Apr 12, 2015 | 03:21 AM
bgoetz's Avatar
Your tuner is correct, that is concerningly low. My bone stock 06 made 210, and my 01 with HFC/I/UK exhaust and VAFC tune made 208. Both on a very consirvative mustang Dyno
Old Apr 12, 2015 | 06:49 AM
proracer07's Avatar
Is there anyway to figure out what the problem could be?
Old Apr 12, 2015 | 10:08 AM
bgoetz's Avatar
Since it is a DBW car I would start with a valve adjustment and plug change if it has not been done in a while. DBW cars were natorious for exhaust valves tightening and regardless of the issue you don't want that.
I would also do a compression test.
Old Apr 12, 2015 | 11:31 AM
windhund116's Avatar
Compression test, for sure. You are really down on torque. Car must feel sluggish, compare to a normal S2000. Car has good air filter and regular oil changes?
JOC, how did he calibrate the dyno?
Old Apr 12, 2015 | 01:29 PM
proracer07's Avatar
Originally Posted by windhund116
Compression test, for sure. You are really down on torque. Car must feel sluggish, compare to a normal S2000. Car has good air filter and regular oil changes? JOC, how did he calibrate the dyno?
I change the oil every 2000 miles, and the car has it's stock air box with a K&N filter.
Old Apr 12, 2015 | 01:35 PM
How does the power feel? You prolly should feel a drop in performance. Maybe, the dyno's numbers are inaccurate?
Old Apr 12, 2015 | 03:53 PM
proracer07's Avatar
The feels fine to me, the tuner does have an actuate dyno called the heart break dyno if that helps. From the previous owner the car was tracked a lot, and it could be suffering from a warn engine. Which I hope it's not, I wanna keep the car as long as I can.
CBR2200
Sep 23, 2011 12:36 AM
NexS2000
Sep 27, 2008 06:57 PM
qbmurderer13
Jan 15, 2008 11:14 AM
qbmurderer13
Jan 12, 2008 08:59 PM
shingles
May 27, 2001 01:41 PM
