Power Steering
Old Apr 23, 2008 | 04:35 PM
onionbagle's Avatar
Default Power Steering
I recently had my power steering replaced about 6 months ago after an accident. Recently I have noticed that it feels twitchy. It actually feels like a power steering system that is low on fluid but I realize ours is an electric motor.
On pavement stopped with engine running and slowly turning the wheel is when its most noticable. It feels like you turn the wheel and the power is struggling to keep up, like a half inch lag.
When driving around 50 any notches or grooves in the road seem to agitate it also.
I just checked my power and it was ~11v off and a steady 12v with the engine running. Isn't it supposed to be around 14v running? Maybe this could be causing my sluggish steering.
Old Apr 24, 2008 | 06:10 AM
snakeeater's Avatar
Yes, your battery voltage should be about 12 with engine off and about 14 with the engine running. Try a new(er) battery.
Old Apr 24, 2008 | 06:41 AM
3ngin33r1's Avatar
Check your tire pressure all around for that one, just to be certain. You may have two problems.
Old Apr 24, 2008 | 09:12 AM
onionbagle's Avatar
[QUOTE=snakeeater,Apr 24 2008, 06:10 AM]Yes, your battery voltage should be about 12 with engine off and about 14 with the engine running.
Old Apr 24, 2008 | 09:18 AM
3ngin33r1's Avatar
Maybe, I've had low tire pressure not show anything on accel or decel but catch grooves more prominently.
Old Apr 24, 2008 | 03:01 PM
cdelena's Avatar
The steering torque sensor probably needs to be reset:
https://www.s2ki.com/forums/index.php?showt...0&#entry9803999
Old Apr 24, 2008 | 04:37 PM
onionbagle's Avatar
https://www.s2ki.com/forums/index.php?showt...33;entry9803999
I will keep this in mind.
I honestly think the sluggish steering is because my alt is only putting out
12v. Does anyone else think this could be the culprit or am I alone?
Old Apr 25, 2008 | 06:12 AM
3ngin33r1's Avatar
The alt is only outputting 12v or the battery is outputting 12v?
Pull the alt and take to an auto parts shop, they'll test it.
Testut
Aug 9, 2006 07:59 AM
LdoubleE
Feb 18, 2006 12:47 PM
jelliotlevy
Jul 14, 2003 07:15 PM
xfactor834
Oct 11, 2001 10:39 AM
William
Jun 20, 2001 05:26 PM
