Problems w/ engine SWAP AP1 to AP2 MY07
Old Aug 26, 2009 | 01:40 AM
Rajdlos's Avatar
Default Problems w/ engine SWAP AP1 to AP2 MY07
I have a problems :-(
My car is MY07 and my turbocharger engine is AP1 MY03.
Engine run ok, but the warnings of airbags, VSA and engine light. VSA is not important, but airbags are.
My diagnostic connector doest work too cause of CAN BUS. I have AEM EMS standalone.
Does exists any resolutions for these errors?
Many tahnks for help
Old Aug 26, 2009 | 08:29 AM
negcamber's Avatar
The MY06+ wiring harness and ECU is completely different from the MY00-05. You're trying to mix and match as if they are all compatible and they are not.
What many MY06+ owners do is to leave the stock ECU in place to run everything but the fuel and timing and then use the EMS like a piggy back to control the motor. You have to use a custom wiring harness to do that.
It probably would have been much better to start with a MY00-05 for your build if you planned on using an MY03 motor + EMS.
Old Aug 26, 2009 | 01:16 PM
Rajdlos's Avatar
I know, MY06+ has CAN bus wirring harness. Its a big problem.
Btw. the engine is in car and run OK, but exist these problems.
I would like eliminate the airbag error, next errors arent important, by VSA I removed the LED lights :-)
sleepinggreys2k
Feb 13, 2010 12:57 PM
FormerH22a4
Aug 13, 2009 11:07 AM
BuBuS2k
Aug 12, 2009 07:28 AM
s2ksang
Feb 26, 2009 09:45 AM
Rajdlos
Mar 24, 2008 01:39 AM
