Problems while shifting maybe?
Old Apr 23, 2007 | 08:40 PM
Le3's Avatar
Le3
Default Problems while shifting maybe?
I have started to notice some problems w/ my s2k
I don't believe I have done anything to cause this problem (this is a used 05 w/ 14k miles) but it only happens occasionally.
When ever i go to like 1st or 2nd from neutral it gets stuck in the left slot in the middle of 1st and second.
Like say |- is 1st (top) and 2nd (bottom) it gets stuck in the middle right there. and then when i notice it i try to push it into gear and my clutch/gears grind together and it sounds really bad. It also happened to me when i was trying to get into reverse as well, it got stuck on the right side of the box and when i tried to pull it into reverse it grinded.
Maybe its just me?
This happens occasionally like maybe 1ce or 2ce every 2 weeks
Thanks,
Jon
Old Apr 23, 2007 | 10:31 PM
jyeung528's Avatar
change your tranny fluid...
Old Apr 25, 2007 | 05:32 AM
snakeeater's Avatar
Remove the shifter from the tranny and put a bunch of urea grease on the ball and socket joint. See the Rick's short throw shifter instructions for pictures of the parts removal process.
Old Apr 25, 2007 | 09:31 PM
s for shweet-2k's Avatar
i noticed that has happened to me too from mostly from 5th to 6th. Occurred just after my accident. haven't experienced the grinding of any kind though. Feels like something broke so its not sliding correctly and smoothly to the gears.
chenpo
Mar 6, 2011 12:00 PM
05Silverbeast
Jul 13, 2009 10:29 AM
basracx
Jul 15, 2007 10:00 PM
enigmadsm
Jan 2, 2007 12:40 PM
FormerH22a4
Jun 11, 2003 04:11 PM
