Pulling the block
Old Sep 16, 2005 | 06:15 AM
  #21
FF2Skip's Avatar
Bill, I looked through the manual(for pulling tranny). It has you disconnect the steering?!
  #22
FF2Skip's Avatar
Originally Posted by billman250,Sep 16 2005, 09:12 AM
Sounds like I could have the engine out faster if I pulled the trans first.
What time do you expect to arrive?
Old Sep 16, 2005 | 06:18 AM
  #23
FF2Skip's Avatar
Originally Posted by Revenuer,Sep 15 2005, 09:00 PM
Skip,
I've got a 3/4" drive ratchet you can borrow. It is only a Craftsman, but at least it wouldn't matter if it broke. It might be hefty enough to do the job, just stick a pipe on it if you need more leverage. I've also got a 1/2" drive breaker bar if you want to give another one a shot (craftsman as well unfortunately)
John
Thanks for the offer, John. I use/buy Craftsman as well. I had to return a hand tool once before... no questions asked.
Old Sep 16, 2005 | 07:58 AM
  #24
xviper's Avatar
That's only because you lower the engine cradle. If you're lifting the engine out, I think the cradle can stay put.
Old Sep 16, 2005 | 08:23 AM
  #25
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Yup....steering is easily disconnected.
1 matchmark
2 position the shaft for easy access to the bolts, then loosen the upper and remove the lower
3 most important....before sliding the coupler upwards, remove the ignition key and lock the steering. If the steering wheel is allowed to float one turn before re-connecting the steering shaft, you'll break the clockspring (cable reel)
I guess I feel it's faster as I've pulled the trans over 15 times
Skip if I was closer I would have came right over with some tools
Old Sep 16, 2005 | 11:03 AM
  #26
FF2Skip's Avatar
I appreciate the help and offerings, guys. I may give it another go tomorrow.
Old Sep 16, 2005 | 02:26 PM
  #27
Slows2k's Avatar
Chris....you think any time is being saved by doing it in one shot?
With the Cylinder head installed, It's impossible to remove the motor/trans combo from the top. If the head was allready off, I'd try pulling both assembled, because you won't have to worry with the head hitting the cowl.
If you have a 4 post lift, it's faster to drop the motor and trans still attached to the subframe.
On jackstands, yank the trans 1st, then the motor.
taylorsmith831
Aug 9, 2015 04:07 PM
s2konroids
May 10, 2012 02:12 PM
GoFaassttt
Oct 7, 2009 07:57 AM
SilvCF2k
Nov 17, 2008 01:25 PM
ChefJ
Aug 6, 2007 12:52 PM
