Pushing Rubber Grommet Back
Old Sep 15, 2014 | 04:25 PM
angleton's Avatar
Default Pushing Rubber Grommet Back
Is there a trick to getting these wire grommets back in under the hood? I'm trying to pin down a leak and noticed mine must have jostled its way out at some point, but my god, I can't get the dang thing back in; there's just not a lot of room to push. Is there a tool or trick that you guys have had luck with? Here's a shot of it when it was in. I can see how it might work if I pull it back in, but that seems like it would require a dash removal.
Old Sep 15, 2014 | 05:11 PM
Slowcrash_101's Avatar
You can use a pipe(pvc, plastic, metal your choice) with a piece of it cut out so you can slip it over the wires and drive it in with a rubber mallet?
Old Sep 17, 2014 | 02:44 PM
street_ruler's Avatar
you talking about the grommet that the engine harness passes through?
put a little shinitsu grease on it and work it in. you may have to remove other things to get better access to it.
Old Sep 17, 2014 | 06:12 PM
Utah S2K's Avatar
Undiluted Dawn dish soap,
Utah
Old Apr 25, 2015 | 09:15 PM
angleton's Avatar
Utah
This worked in case anyone is searching for a solution.
Old May 8, 2015 | 06:17 PM
daviddi92's Avatar
Anyone know where I can buy that grommet? I don't have it and cant find it. Every time it rains It leaks through there.
Inteligentleman
Aug 23, 2016 12:34 PM
poss87
Jun 20, 2013 07:37 AM
Turn-R-Us
Sep 26, 2009 09:49 AM
BowlofRice
Apr 18, 2007 05:11 PM
evilbeatfarmer
Apr 18, 2005 08:29 AM
