Question about ABS
Old Aug 20, 2007 | 03:59 PM
owenxguo's Avatar
Default Question about ABS
I was unpluged ABS bump for couple track session, and pluged it back the next day, but ABS light still there and ABS not working. Like SRS light you have to bypass the pins. I know normally if it's good the light should be gone after few mins driving, but is there anything I have to do for ABS?
Old Aug 20, 2007 | 04:36 PM
mikegarrison's Avatar
Pull the code and see what it is.
Old Aug 20, 2007 | 07:25 PM
owenxguo's Avatar
From where? OBD2 or Scanner?
Old Aug 20, 2007 | 08:18 PM
Slows2k's Avatar
Generic OBDII scanners can't get an ABS code. Take it to a dealer to get the codes pulled is probably the easiest way.
Otherwise you'd have to jump the SCS pins in the DLC connector and count the flash code. (which can be a PITA if you are not mechanically inclined)
Old Aug 20, 2007 | 08:51 PM
KstreetDC's Avatar
Yeah I am having this problem as well.
bgioan
May 15, 2014 06:40 PM
JohnnyAnonymous
Feb 9, 2009 05:00 AM
a_zepeda926
Jan 30, 2009 05:17 PM
S2FiONE
Aug 10, 2006 06:32 PM
