QUICK WIRING HELP... INJECTORS.
Old Jan 20, 2009 | 08:17 PM
SPECIAL-OPS-S2K's Avatar
Default QUICK WIRING HELP... INJECTORS.
Searched and searched and could not find the answer... I am wiring in my injector clips for my Bosch 1000cc Saturated injectors and its been awhile since I worked on the car... the OEM clips have been removed for awhile and the wires layed across the intake manifold... anyway I can pretty much tell from the lengths which set goes to what cylinder but would love confirmation. I noted that each injector has a yellow wire with a black stripe feeding it 12v and then a corresponding ground wire of a different color for each cylinder. I think there is a BROWN, YELLOW, BLUE, and RED.
From firewall forward I believe the order is YELLOW, BLUE, RED, BROWN...
Is this correct?
If anyone could check for me or has a diagram please post it up so I make sure I dont screw this up!
Thanks
J
Old Jan 21, 2009 | 05:45 AM
negcamber's Avatar
If you don't get an answer here, you might ask in the FI forum since it is much more common for the FI guys to swap injectors.
Old Jan 21, 2009 | 09:39 AM
SpitfireS's Avatar
This is from the MY00-03 manual.
Old Jan 21, 2009 | 02:13 PM
thanks!
08s2000CRbackinblack
May 25, 2010 02:01 PM
lotus7racer
Jul 22, 2009 09:51 AM
GDM S2K
Oct 31, 2006 03:14 PM
PRS2K
Jul 10, 2006 07:00 PM
Ztec
Apr 2, 2005 07:32 PM
