Re-wiring electrical system and
Old Apr 25, 2008 | 07:31 AM
2QYK4U's Avatar
Thumbs up Re-wiring electrical system and
My S2000 is becoming a drag race only car. Yes, that's right, I am turning an S2000 into a drag race only car. Go figure. To each is own right?
Anyways, I am curious to know what the level of effort/expertise would be required to re-wire my S2000's electrical system and remove unnecessary wiring. Essentially I only need wiring that would allow the car to drive. I've removed my VSA, speed sensors, SRS, a/c and heater system, radio, etc. and most of the wiring going to those items. I know that professional drag cars are completely stripped down and although I won't be entering the professional arena I would like to remove as much wiring as possible and reduce the risk of any electrical failures.
Thoughts?
Old Apr 25, 2008 | 07:47 AM
3ngin33r1's Avatar
well, you could buy a new engine harness, gut the car of all wiring, install the new harness and you're set.
You'll have a spare harness that way too, you never know if you'll burn one up.
Old Apr 25, 2008 | 07:56 AM
2QYK4U's Avatar
That's a pretty good idea! I would like to retain certain functionalities like headlights and taillights, but pretty much everything else could go.
Old Apr 25, 2008 | 08:01 AM
2QYK4U's Avatar
BTW...I'd like to keep my current engine wiring harness because I paid my stereo shop around $400 to beautify it:
Old Apr 25, 2008 | 08:15 AM
3ngin33r1's Avatar
well then if you've already got it out, what else do you need to know?
You don't need lights. You'll need ignition power to the fuel pump and I can't really think of anything else that's not already taken care of by the engine harness. EPS is optional, if it's drag only, I don't know why you'd need it.
Old Apr 25, 2008 | 08:24 AM
2QYK4U's Avatar
Sorry...I guess I sort of talked myself through it. I need the headlights for drag racing at night. Call me a wus but I'll probably retain the EPS. My car is getting so freaking light that I need to remember to leave some parts simply for added weight!
Old Apr 25, 2008 | 08:25 AM
3ngin33r1's Avatar
Well, you could pull the HID ballasts and lights and just power the high beam incandescents for night racing.
Old Apr 25, 2008 | 08:28 AM
2QYK4U's Avatar
Do you think that would be overkill, or is it simply a part of going all out? Shoot, I may need to look at having the car acid dipped!
Mike_LHF
Jun 27, 2018 08:28 PM
nissfam
Apr 5, 2013 08:11 AM
az3ar
Feb 18, 2013 05:01 PM
A51_AP1
Dec 5, 2010 08:29 AM
emrillive
Dec 16, 2004 03:03 PM
