Rear subframe removal, do I need to remove the driveshaft
S2000 Technical and Mechanical discussions.
Feb 3, 2017 | 04:29 PM
bgoetz
Sep 2008
Can I just unbolt the drive shaft from the differential and swing it down or do I need to remove the entire thing?
bgoetz
Find More Posts by bgoetz
Feb 3, 2017 | 05:00 PM
Singh_snisen
Jan 2017
United States
bgoetz
i left mine on a jack stand. U don't need to remove the prop shaft.
Singh_snisen
Find More Posts by Singh_snisen
Feb 3, 2017 | 06:17 PM
bgoetz
Sep 2008
Singh_snisen
ok cool so you just unbolted the rear diff and lowered it from there?
bgoetz
Feb 3, 2017 | 08:02 PM
Singh_snisen
Jan 2017
United States
Unbolt prop shaft from diff. Drop subframe.
Singh_snisen
Replacing differential rubber mounts
S000M
03:39 PM
rear diff swap
DP's-s2k
09:37 PM
Pulling diff
airdawg
05:31 AM
Question about rear differential removal?
00SpaYellow
10:41 AM
Ball Joint puller?
Stratocaster
Jun 12, 2003
10:18 AM
Back to Subforum
View Next Unread
Oil Change
11:30 AM
