Redline Diff Fluid
Old Nov 14, 2005 | 03:05 PM
DaveZuck's Avatar
Default Redline Diff Fluid
Hey Fellas
I tried the search function but it wasn't working
Has anyone tried redline diff fluid? My mechanic, who is a very well regarded S2000 tuner here in SoCal, let me know that he went with Redline diff fluid instead of the OEM Honda fluid.
I seem to be getting a bit of low rpm whine under acceleration in gears 1 and 2. But no whine in other gears or when already up to cruising speed.
Is this normal?
Anybody else runnin the redline diff fluid?
Any feedback is appreciated.
Old Nov 14, 2005 | 03:11 PM
xviper's Avatar
This would be pretty easy since there is NO OEM Honda diff fluid. Your Honda dealer must get it from Honda motorcycle division.
If you put Redline Shockproof into your diff, you might want to know this:
https://www.s2ki.com/forums/index.php?showtopic=141409
Old Nov 14, 2005 | 04:03 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Been using Redline 75W90,gear oil for quite some time,and never any problems, or "whining".
Are you sure the whining was not there before?
Change it to Mobil 1,you'll see if it goes away!
Old Nov 15, 2005 | 11:06 AM
Venomous S's Avatar
I was using Redline Diff fluid for a while on my stock diff some time ago and I had no issues until my rear blew. The rear didn't blow because of it however.
If you have a mechanical whine, by trying diff fluid will not quiet it. Maybe a slight bit but not really.
Old Nov 15, 2005 | 11:31 AM
ToeKneeC's Avatar
another RL 75w90 user here... (and hence another data point?)
was on whatever-the-stock-fluid until last month. changed out to 75w90 (stock fluid was still near crystal clear), no increase in whine/noise... now that Tanabe catback OTOH....
Honda_Lover
Feb 26, 2017 07:43 AM
Sub_01
May 20, 2009 07:08 AM
red 2000 s2k
Mar 26, 2009 11:11 AM
EriS2k
Mar 18, 2009 04:54 AM
s2kbenztech
May 14, 2008 03:35 PM
