Regrease shifter DIY
Old Mar 6, 2015 | 11:02 AM
  #131
spectacle's Avatar
For anyone coming across this (great) DIY, I wanted to give my 2 cents.
I didn't bother trying to order the Honda grease. I picked up some Mobil 1 high temp grease for $9 at Autozone and went to town. My car is an 01 with 89k and definitely felt like it needed the service. I'm happy to report that afterwards, it was a night and day difference in shifting feel.
Also, do not be intimidated by the plastic retaining ring on the rubber boot. If you follow this tip:
Originally Posted by hyperkin
just a little tip on how to remove plastic ring for the rubber boot, if you by any chance have a very tiny flat screw driver for opening iphone or for watches or glasses, it will be a very good tool. start by pulling the rubber inside the ring, you will see a little opening at the buttom of the plastic ring, then you just poke the screw driving into there, and give a little pull on the outside of the ring, it should came off easily, then you do the same for two more side, the last side will just came off itself. and i did not remove the plastic ring from the rubber, they came off in one piece.
It will come off in NO TIME with zero issues!
In the pic, the new Mobil 1 grease is red
Old Mar 22, 2015 | 03:15 AM
  #132
Jael_marshmellows's Avatar
Great write-up. Tried this and I was very liberal with the grease. Only noticed a slight difference but thats ok. I suppose my shifter wasn't in much of a need for re-greasing. Great day-off job.
Old Mar 24, 2015 | 04:52 PM
  #133
The Machine's Avatar
I am going to be doing this at some point as well. My car has 127k on the clock and I'm not sure if any of the previous owners have ever cleaned and regreased. Sometimes shifting between 1st and 2nd is nice and smooth, but the majority of the time it is very notchy. Trans fluid was just recently changed as well when the new clutch was installed.
Old Jun 23, 2015 | 10:35 AM
  #134
boostinbort's Avatar
Does anyone know the part number for the insulation foam or where I can buy some? I have some. Kind-of foam about this consistency but I don't know if that other foam was heat resistant etc.
Old Aug 3, 2015 | 09:25 AM
  #135
EGbeater's Avatar
Originally Posted by Saki GT
Inspect the ball cap for any cracks or chips - if its bad, replace it. Pivot ball at the end of the shifter = 54111-S2A-003 COVER, PIVOT $2.02
Yikes, I'm surprised that in five years, Honda has jacked the price up on that tiny little plastic part at the tip of the shifter—54111-S2A-003 ("Cover, Pivot")—from a reasonable price, to a completely UNREASONABLE $19.25 list, $13.28 + shipping at Majestic Honda... the cheapest I can find the 54111-S2A-003 for today is via Honda Parts Unlimited in Phoenix, Arizona... they're charging $13.86 for the part, and only $2.30 for shipping via USPS First Class.
A couple negative reviews for HPU on Facebook saying shipping/delivery of their part took forever, but there's three 5-star review ratings too... I'll report back on how they do for me:
https://www.facebook.com/pages/Honda...95506140598096
Old Sep 11, 2015 | 12:28 AM
  #136
S1 S2's Avatar
Thanks to this thread. Noticeble improvement nothing crazy though.And that reverse gear trick
Old Sep 13, 2015 | 12:33 PM
  #137
noodels's Avatar
After fitting the above and all fluids changed I investigated the clutch pushrod free play and adjusted it,
wish I had looked there first
Old Feb 11, 2016 | 09:58 PM
  #138
sacjs's Avatar
Long story short, then a question. Followed this write up and it worked for a while... then the shifter would no longer "pop up" from reverse. Replaced the spring...then the wonderful plastic bearing cracked and got lodged in place. Replaced the whole shifter assembly with an Axial Flow & Moddiction knob. Absolutely wonderful... for about 2 weeks. Now the shifter will no longer pop up (again) and takes some force to unstick. I have looked into an upgraded shifter spring, and found a company called Mtec that makes upgraded shifter springs for the K series. It works perfectly for the K20\24 guys, so...
Are K & F shifter springs interchangeable(or at least the same diameter)?
Old Apr 13, 2016 | 03:30 AM
  #139
Wojofoo's Avatar
Finally completed this last Sunday. When I bought the car last year, the shifting felt notchy (especially 1st gear / into 2nd gear)
The car has ~70K miles and this is what it looked like.
While it still seems a little notchy, it is certainly better. It also seems to be improving each and every day as the grease moves around.
For others that may do this, I used about 2/3 of the Urea grease.
Old Jul 7, 2016 | 07:38 AM
  #140
Lovetodrive2000's Avatar
Just did this..... not difficult at all.
The foam insulation ring on my car had deteriorated to the point of just being "mush", and was all over the place.
Would recommend having the shifter in neutral when you take it apart. Goes back together a lot easier.
For re-assembly I used 3 thin phillips screwdrivers to get the holes lined up, then took one out, pushed down on the assembly (easier on the hand with the knob on the shifter) and got the first bolt in and most of the way tightened, then put in the other two (to keep the bolt in the socket, just put a little grease on the bolt and it will stay in the socket!).
Took maybe 30-45 minutes to do.
Really can tell the difference when done!!
to the OP for the DIY!!!!
