Regrease shifter DIY
Old Nov 20, 2017 | 03:27 AM
  #171
DJ8684's Avatar
I just did this same maintenance job yesterday actually. Changed all the same parts and also don't forget the foam insulation piece that surrounds the shifter. I've had 3 S2000s and had no idea this even existed until I did the job on this car. The foam turns into this play-doh-esque type material and falls apart. I had to vacuum it out. The part number for that is 74699-S2A-000. I'm going to post my step-by-step on what I did with part numbers and all in my thread in the automotive builds section later today. Also, I put the pivot ball in a cup of boiling water for 10 minutes before popping it on to the shifter and it snapped in like butter.
Old Nov 20, 2017 | 01:49 PM
  #172
DJ8684's Avatar
https://www.s2ki.com/forums/automoti...1176305/page2/ The link to my build with tons of detailed photos from when I did this job.
Old Oct 8, 2018 | 06:46 PM
  #173
DJ8684's Avatar
I've actually heard that it's quite common that they crack during the install. Did you try the boiling water trick?
Old Dec 9, 2018 | 09:20 AM
  #174
Glepage22's Avatar
Damn it. Me too, was doing this job yesterday and I exploded the bottom pivot ball when reinstalling it. Order a new one and will try to boil them.
Old Dec 17, 2018 | 04:13 AM
  #175
BootsS2K's Avatar
Anyone know the torque spec for the shifter bolts?
Old Dec 17, 2018 | 04:16 AM
  #176
BootsS2K's Avatar
got it. 7ft/lb
Old Dec 17, 2018 | 07:47 AM
  #177
Say Chi Sin Lo's Avatar
I'm wondering if this helps with the reverse engagement?
I don't have issues with any of the forward gears. But man... more often than not, getting into Reverse is like a workout sometimes.
Shifter was recently regreased by the previous owner but unknown if the plastic pieces were replaced, thanks!
Old Dec 17, 2018 | 10:14 AM
  #178
Deckoz's Avatar
yes it should make reverse easier. finding 5th and reverse was a chore before I did this.
Old Dec 17, 2018 | 11:23 AM
  #179
Thomas Guide's Avatar
Another recommendation I learned here is to put it into 1st gear, and when the clutch pedal still pushed in, then go into Reverse. My reverse was always a pain, as are many others, I have been doing this trick for years and get into Reverse super easy.
Not sure why this works but it does.
Old Dec 17, 2018 | 11:25 AM
  #180
Same here, rowing it into 1st helps with the reverse gear re-attempt. Sometimes, I have the row it through 5th and 6th first as well.
I was just wondering if there's a remedy for the reverse. Cause uhh... 3-point turn gives me some serious anxiety with this car, hahaha.
