Removal of air pump=code p1415
Old Jul 12, 2006 | 04:07 PM
gerryk's Avatar
Default Removal of air pump=code p1415
My cel returned code p1415- current sensor voltage low,air pump electrical circuit. Well I removed my air pump a year ago while prepping my car to race, no problems until recently as my car began smoking at hi revs. My A/F ratio is rich @12.1 near 8k-9k, are these 2 issues related?
Old Jul 12, 2006 | 04:31 PM
Slows2k's Avatar
The Air pump isn't related to the engine smoking at revs. The pump only operates at cold start for less than a minute.
What PCM are you using?
Old Jul 12, 2006 | 06:03 PM
gerryk's Avatar
What do you mean by pcm?
Old Jul 12, 2006 | 06:19 PM
Slows2k's Avatar
PCM = ECU =Computer that's running the engine.
I'm asking because a stock PCM won't run without throwing a CEL wth the Air pump removed.
Old Jul 12, 2006 | 06:27 PM
gerryk's Avatar
I am using the stock ecu, and you are right it has thrown a cel #p1415
Old Jul 12, 2006 | 06:31 PM
Slows2k's Avatar
Only way to get the CEL gone is to put the air pump back. Or switch to a AEM EMS or a JDM "tuned" ECU that eliminates the emmisions controls. (Mugen, Spoon, J's )
There is no simulating the air pump to make the PCM happy and not get a CEL.
The smoking at high revs is another issue.
Old Jul 12, 2006 | 07:48 PM
Ek9's Avatar
Ek9
Banned
What kind of smoke, black, blue or white? What's it smell like?
Old Jul 13, 2006 | 03:03 AM
CoralDoc's Avatar
Does the smoking occur in hard right-hand turns? If so it may be the well-documented oil burn when oil is sucked into the intake manifold.
If the smoking occurs only a high RPMs on the straight, it is a different issue.
Old Jul 13, 2006 | 05:12 AM
gerryk's Avatar
not sure of the exact color--pretty sure it wasnt black. most often the smoking will occur after a long fast left hander followed by a straight and a 4- 3down shift at the end of that straight, also after a long straight and a quick off throttle condition such as exiting the track quickly without a cool down lap. (plz no lectures about avoiding cool down laps)
cthree
Apr 12, 2024 08:51 AM
wicked357
Apr 6, 2012 10:22 AM
LazyProfessor
Oct 6, 2009 06:20 PM
herecomesboost
May 14, 2006 06:53 AM
BoyGeorge
Mar 15, 2006 11:37 AM
