removing axle nut
Old Jul 24, 2002 | 10:41 AM
The Unabageler's Avatar
Default removing axle nut
any tips on removing the axle nut?
Old Jul 24, 2002 | 10:59 AM
j2k's Avatar
j2k
I assume you're talking about the rear end of the car, right?
You're going to need either an impact gun or a big breaker bar to get it off. Then the first thing to do is to undo the stake in the nut a bit. You dont have to totally flatten it back out, just try to get a screwdriver under there and ease it back a bit. While the stake will help the nut from coming undone by itself, it doenst provide all that much resistance really... Finally, I'd reccomend first loosening the nut with the wheel still on the car.. touching the ground, and parking brake on. The car being in gear is not enough resistance to get the nut off. You'll just start turning the engine over...
Have fun!
-jason keeney
Old Jul 24, 2002 | 11:10 AM
marcucci's Avatar
Yes- parking brake on, in gear, with someone standing on the brakes. Break torque, then get the thing lifted up and off of the car.
This would be a good time to find a 3/4" or 1" breaker bar. You will likely twist the head off of a 1/2" with more than 2' of "cheater." Impact grade sockets and adapter (if you go 3/4) is a good idea.
I found a 1" breaker from Napa with an 18" long handle, it's managed fine with 3' of cheater on it before. Works great!
Slammed_s2k
Jul 9, 2015 07:47 PM
austincrx
Mar 1, 2015 04:58 PM
trAP2
Jan 20, 2012 07:53 PM
3AM
May 6, 2010 04:32 PM
jert534
Aug 9, 2006 08:19 PM
