Removing top nut from shock
How do you take off the nut that holds the tophat to the shock shaft? I tried to do this on some buddyclub coilovers but the strut shaft just spins with the nut. Even using a vice grip with some rubber padding on the teeth could not keep that shaft from spinning. If anyone has some ideas as how to do this please let me know. Thanks!
With the stockers you use an allen wrench to keep the shaft still while wrenching on the nut.
With Koni Yellows you use a very small boxend wrench to hold the shaft still.
Hope this helps.
If you can take a pic of the top of the shock I can tell you what you need.
Hope this helps.
thanks for the tips guys! i'm going to try the boxend wrench. i wish i had some power tools for this, but hopefully i can get it done without. i'll post up a pic if i can't get the nut off.
if you have airtools, it would make things easier, but it's not necessary. just use an allen wrench and a 14mm wrench turning in opposite directions. spring compressor would make things easier too, but again, if you dont have one, they are not necessary, but would make things a lot safer. good luck.
Kyle R
Kyle R
looks like airtools are my only solution. can't use the allen wrench because it would just turn the damping adjustment knob. the reason i want to remove the tophat is because i have the newer version of the buddyclubs with the secondary spring hat. the previous owner took the secondary hat off in order to slam the car, but i want to put it back on.
akimoto168
Mar 27, 2009 12:44 PM
