Replacing the AC compressor
Old Jun 24, 2007 | 04:45 AM
sookie626's Avatar
Default Replacing the AC compressor
can anyone please give me some advice!
my AC is not working and they told me it was the compressor
I bought one and gonna replace it.
is it as easy as:
loosening the belt,
removing the hoses,
removing 4 bolts
and replace with the other compressor
then filling the "L" with the Freon.
does that sound right
or should I worry about the levels in the"H" too.
Looks easy but should I worry cus its alot more complicated than that!
some 2cents will be appreicated!
thanx
Old Jun 24, 2007 | 08:29 AM
Slows2k's Avatar
Charging a AC system is not like filling the engine up with oil.
The recovery and charging equipment required to do the job correctly costs far more than most DIY'rs are willing to invest.
The receiver drier needs to be replaced as well, then the system must be held under a vacuum to remove all moisture.
Simply adding refrigerant to a a system that hasn't been evacuated will result in charging the system with air as well, which breaks down the oil and causes elevated pressures as well as not cooling properly.
Removing the compressor and reinstalling is the easy part. Correctly evacuating and charging is the hard part.
It's also illegal to vent R134a to the atmosphere and not recover it.
Old Jun 24, 2007 | 10:06 AM
sookie626's Avatar
Thank you,
sounds like I should take it to a AC specialist.
jjaypal
Apr 18, 2017 09:14 AM
Kyushin
May 11, 2011 05:55 PM
ScienceofSpeed
Feb 18, 2009 12:46 PM
trinis2001
Nov 22, 2007 07:56 AM
sookie626
South Florida
Jun 23, 2007 01:45 PM
