Retainer inspection
Old 03-11-2016, 12:11 PM
08S2000's Avatar
Default Retainer inspection
I inspected and took photos of my retainers after a valve adjustment. After reading posts about how to inspect retainers and evaluating mine, I am leaning towards a conclusion that my retainers look "sunk" so possible that I have cracked retainers, especially when I compared to Soviet's photo on this thread (post #4) @ https://www.s2ki.com/s2000/topic/114...r-replacement/
The most difference I noticed was that my cotters look sunk where and Soviet's cotters look flushed with the retainers. Could it be a design change between ap1 and ap2 retainers? I am not sure if Soviet's photo was from ap1 or ap2.
I am hoping I am wrong. Below is a photo of my exhaust retainer for cylinder #1 @ TDC (I believe). Rest of the retainers look very similar so I chose a clear picture to post. https://www.instagram.com/p/BC05RGzEIQ7/
MY08 with 86k miles. How does it look?
Thank you for your time.
Old 03-11-2016, 12:56 PM
08S2000's Avatar
Ok....I am answering my own question now. I searched more and found this thread differentiating f20c and f22c retainers.
https://www.s2ki.com/s2000/topic/442...ring-retainer/
Soviet's photo looks like a f20c retainer.
I still need someone to chime in to evaluate the condition of my retainer... thanks.
Old 03-11-2016, 01:49 PM
Billman250's Avatar
Received 1,312 Likes on 796 Posts
Your Ap2 retainers are fine, guaranteed.
Broken retainers are a non-issue 04-09.
Old 03-11-2016, 02:15 PM
08S2000's Avatar
I learned from the research that the design improved but did not know that it was a non-issue for ap2s.
Thank you for your input.
Old 03-11-2016, 04:19 PM
Soviet's Avatar
Those pictures were indeed of my F20C retainers. Not a single one of mine was cracked but I upgraded anyway. As Billman said you should be good.
Old 03-11-2016, 08:43 PM
08S2000's Avatar
Thanks for your reply. Now I know that oem retainers for f20c and f22c look different.
Old 03-13-2016, 06:31 AM
Slowcrash_101's Avatar
They can crack, but you'll get valve float before that even becomes an issue. In other words you're more likely to bend a valve than crack a retainer.
felixjoel77
06-01-2017 04:02 PM
CRVRX
Tampa
13
08-11-2013 01:59 PM
starrman
10-06-2012 02:27 PM
Blk Prl
09-26-2012 09:38 AM
TwisS2000
04-23-2012 07:55 AM
Quick Reply: Retainer inspection
