Rocker arm assembly removal
Old Nov 15, 2013 | 08:25 AM
liybzd's Avatar
Default Rocker arm assembly removal
I'm working on replacing head gasket, but stuck with the rocker arm assembly. After removing cam and cam caps the rocker arm assembly doesn't even budge a little.
Did some search online and found that some dowel pins are holding some, so I use a rubber mallet and tried to tap them loose, but nothing happened. I even used a wrench to pry, still stuck.
I've attached a photo, thanks for any suggestion.
[attachment=48843:1.jpg]
Old Nov 15, 2013 | 08:31 AM
MM3Kwolik's Avatar
I usually use a large phillips screwdriver that is just about the size of the holes where the bolts go through and insert it almost all the way and do a side to side rocking motion on each section to pop them loose. This will prevent damaging of the threads in the head and possible damage to the cam journals and/or rockers/rollers.
I've used this method on every S2000 where I've needed to remove the rocker assemblies (about 30 or so times now) and have had nothing but success. Good luck.
Old Nov 15, 2013 | 08:32 AM
MM3Kwolik's Avatar
Due to the orientation of you picture, it'd be a front/back rocking motion. (side to side if facing the engine from the front)
Old Nov 15, 2013 | 12:06 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You can also use two Philips screwdrivers, and squeeze them together making a handle that is locked to the cam cap
A short ended right angle prybar (must use care and discretion here as to not mar any aluminum surfaces) will pry the assembly up with ease. Do one end, then the other.
Old Nov 15, 2013 | 08:16 PM
liybzd's Avatar
Post
Thanks for you suggestion
Old Nov 15, 2013 | 08:31 PM
liybzd's Avatar
Cool
Thanks for your suggestion, I used two screwdrivers, one lay on the block, put another on the top and use it as prybar. The assembly came off instantly. I also use some rag in between to further protect the block.
shogunmma
Feb 8, 2019 06:58 PM
GreenmanS2000
Car Talk - Non S2000
20
May 28, 2015 10:48 AM
SPECIAL-OPS-S2K
Nov 14, 2007 09:42 PM
TheCarGuy2021
Mar 25, 2007 08:20 AM
carrera0to60
Jun 25, 2006 10:35 AM
