Rod Knock?
Hi guys i posted before with a possible tick issues replaced the tct, the oil pressure switch, and a few other sensors the tick is gone buuuuut now my knocking has began suddenly...as soon as it happened i parked it and had it towed home. Havent had a chance to drop the oil pan but i know its gotta be it any suggestions on known lower engine rebuild kits...is it even salvagable? Please tell me it is and on a budget lol
Well got the oil pan pulled off. The rod is tapping because my bearing is bad. No scores on my walls. In my oil pickup i found some trash blocking it. Ill go back and swap it out as soon as my shipment comes in
There are threads on this. Billman has saved many motors in this condition by hand polishing crank, and replacing bearings. All done with motor in car.
If you can tow to him (LI NY), do it. Otherwise you can try tonfind someone local or DIY if you feel up to it.
I appreciate it man. Im getting the cloth today from work (i manage an autozone) and doin a light sanding waiting on my bearing set to be sent in then flush the motor after applying the new bearings
Cut open the oil filter to see what made it there. I would run a larger oil filter till you know the new bearings are going to last.
I run a larger oil filter on my S all the time
Here are some pic's of the OEM S filter, Wix filter(don't use) and the larger oil filter.
In the last pic you see the filter part of my Baldwin, Honda and the much smaller Wix filter. That is why I wouldn't use the Wix.
Get a Baldwin B202(same size as the B7042 but the B202 has a higher by-pass setting). You don't want the oil filter to go into by-pass at all with that junk floating around the engine. The larger filter will take longer(high rpm cold start) to get into by-pass if it will even get there at all.
Good luck on your engine,
ROD
ROD
YES !!!!! You want to keep the oil filter from going into the by-pass mode, the larger filter will help keeping the oil filter out of by-pass. You know you can't get all the junk out of the engine, so why risk putting that junk right back to the bearings? If you have the old oil filter, cut it open to see what made it there. If you find ANY junk, some of that crap can and will go right to the engine around the oil filter IF the oil filter went into by-pass.
ROD
ROD
