Rotating shock piston
Old Feb 18, 2009 | 04:07 PM
FuzzieLogik's Avatar
Default Rotating shock piston
Well i adjusted my megan track coilovers via the way a few other people have. I left the coilovers on and loosened the bottom ring and started turning the whole shock assembly down. Now, a lot of people have done it this way apparently, but i noticed the shock piston was turning. Is this harmful for the coilovers? I always thought it was.
Thanks!
Old Feb 18, 2009 | 04:59 PM
macr88's Avatar
Do you mean the shaft?, the piston is inside the body. Yes it's ok if the shaft turns at the shock body.
Old Feb 18, 2009 | 10:02 PM
yes i mean shaft. sorry. So if the metal shaft is spinning that is no big deal right? Thanks!
Old Feb 18, 2009 | 10:18 PM
macr88's Avatar
It's fine, you don't want to spin it high speed like with an impact gun for long periods. The seals can heat up and get damaged.
Old Feb 18, 2009 | 11:02 PM
phew! The whole time while i was lowering the shock body watching the shaft spin i was thinking to myself: "oh jesus...im screwing up a brand new set of coilovers.."
Old Feb 19, 2009 | 05:18 AM
Rex Leo's Avatar
Hey if you don't mind since you have the Megans as well, can you tell me what the distance was of the spring to the small locking nut at the bottom perch out of the box? Or what you have it set to currently?
Also wondering on how much drop you have vs. how much shaft is exposed between the bottom locking nut and the lower locking nut on the bottom perch.
Old Feb 19, 2009 | 07:26 AM
oh man i really dont remember. I dropped the rears about 1.5 inches on the shocks themselves.
The fronts, probably similiar
KillerCom
Jun 23, 2011 07:33 PM
darksparkz
Apr 20, 2010 11:08 PM
westmobs2k
May 26, 2009 07:42 PM
dbzerk
Jan 18, 2007 07:21 AM
marcucci
Mar 9, 2005 07:44 AM
