Rough/Unusual Idling
Old Aug 20, 2012 | 01:07 PM
cranked911's Avatar
Default Rough/Unusual Idling
Hello all, frist time posting. First off I have a 2000 s2k which I bought used a couple months ago. It has a rebuilt engine and 168k miles. When I drive the car and prepare to stop, say, at a red light or a stop sign, the engine will go back down to idle speed but it will go a couple 100 rpm under what it is suppose to be and make a "a rum rum" sound and then go back up to the proper idle speed. Sometimes it gets so low that on the tach there are only 3 "lines" measuring the rpm. My question is what is causing the problem and if I can fix it myself, as the engine was already rebuilt 6 months/10k miles ago by the previous owner.
Old Aug 21, 2012 | 06:39 AM
Reckon's Avatar
Double check hoses and the air filter. Perhaps the IAC needs a tweak?
Old Aug 22, 2012 | 04:58 PM
cranked911's Avatar
I checked the air filter and its filthy. I think its a K&N filter so I'm going to clean that or if it isn't i'll just change it. Im going to check/clean the IAC later this week when I have some time and when you say double check the hoses what specific hoses are you recommend I check?
Old Aug 23, 2012 | 09:02 AM
DeeKay's Avatar
Mine does the same, rarely, but it does happen.
First time I saw my MAP sensor connector wasn't full secured, so I pushed it in and zip-tied it. I have still ran into this issue even after securing the harness. My PCV is clogged (which I am replacing today). I've already cleaned my idle air control valve.
I'm not sure what else to check, although like I said the problem is rare and intermittent.
Old Aug 23, 2012 | 11:41 PM
lunardeathgod's Avatar
I have a similar problem too, it happens maybe once in awhile. I always thought it was just bad gas
Old Aug 24, 2012 | 07:27 AM
Mezza's Avatar
Do you have a check engine light?
Old Aug 24, 2012 | 10:17 AM
cranked911's Avatar
nope check engine light has never came on since I had the car.
Old Aug 24, 2012 | 02:35 PM
DirtySouthS2K305's Avatar
As someone else previously stated, check your IAC
Old Aug 25, 2012 | 06:55 PM
cranked911's Avatar
Ok I just cleaned the air filter and the IAC. The IAC was really dirty and I cleaned it. This lessened the intensity of the bogging but it still bogs. It use to bog down by 500 or so rpm now it only bogs 100-200 rpm. Im going to clean the IAC again tomorrow and do a more thorough job as I half assed it.
MercGuy
Jul 3, 2016 10:41 AM
Lance_M
Apr 13, 2008 05:02 AM
tritium_pie
Jan 3, 2006 08:21 AM
Mark16q
Feb 26, 2005 10:15 AM
LostWaffle
Apr 1, 2004 09:07 AM
