S2000 Fluids
Old Aug 7, 2017 | 09:12 AM
  #21
miloking's Avatar
Originally Posted by S2K632
I have an AP1 with 76K miles when decelerating the transmission or clutch is noisy. Is there a trans fluid that will minimize this sound and protect the trans.
fluid will not fix 'ap1 clutch buzz'... you need upgraded clutch disk (i belive the part number ending with ...-55)
Old Aug 7, 2017 | 04:35 PM
  #22
thegolffather's Avatar
Thanks
Old Jul 14, 2018 | 12:09 PM
  #23
jinn's Avatar
MY04 w/ 89,000 miles
Engine: AMSOIL Signature Series 10W-30. *Will test AMSOIL XL 5W-30
Oil Filter: HONDA PCX or AMSOIL
Brake/Clutch: ATE Type 200 DOT 4
transmission: HONDA MTF, * Will test 50/50 mix AMSOIL & HONDA MTF
Diff: AMSOIL 75W-110
Coolant: PENTOFROST A3
Comments
Engine: Minute oil consumption. Pour only 1/5th of a qt before next oil change. Going to XL, I don't think Signature Series is necessary until baller is a factor.
Transmission: 2nd Gear lockout hear & there. I will be doing a 50/50 mix from a recommender I met.
Old Jul 14, 2018 | 09:42 PM
  #24
Singh_snisen's Avatar
A little info on the car. Pure race car. Stock block with a built head. Rebuilt trans and diff.
Engine: Mobil 1 10w-30 or 5w. Depends on my application
trans: redline mtf. Great cheap fluid that can take the heat. Hate the Honda mtf for my application.
Diff: Mobil 1 gear oil or redline. Whichever one I can get my hand on.
Brakes : Castrol SRF. I have used the ate type 200 and motul. I honestly like the ATE better than the motul for the price.
Cooling: Oem Honda coolant. Temps stay under 200 in the California dessert with temps over 110.
Old Jul 20, 2018 | 06:47 AM
  #25
CMK's Avatar
CMK
MY03 with 87k miles
Engine: 10w30 Amsoil XL / OEM PCX filter
Brake: Prestone DOT 3
transmission: Amsoil Synchromesh
Diff: Amsoil Severe Gear 75W110
Both engine and transmission run smoothly. 2nd gear can be notchy but I'm never locked out. Haven't sent anything off to Blackstone. Oil changes performed yearly, car only sees about 3k miles a year. Only driven in fair weather, no track or autox.
Old Jul 20, 2018 | 07:03 AM
  #26
Yknits18's Avatar
MY05 with 104,000 ish miles
Engine: 10w30 Royal Purple synthetic with Royal Purple filter
Brake: Honda
Clutch: Honda
Diff: Royal Purple 75w110
Coolant: Honda
I do not track my car. I use her for spirited canyon driving and top down cruising.
Old Jul 20, 2018 | 08:24 AM
  #27
IA-SteveB's Avatar
Lots of variance in the differential oil viscosity.
Old Jul 21, 2018 | 04:54 AM
  #28
Mr.Matchbox's Avatar
Engine: 2 quarts Redline 10w-30 + 5 liters Penrite Racing 10 10w-40 mixed to get a thick 10w-30 and a little Liqui Moly Ceratec
Oil Filter: OEM Honda
Brake/Clutch: DOT 4 or 5.1
transmission: Ravenol MTF II 75w-80
Diff: Ravenol SAE 90 GL5 or Castrol 75w-90 GL5
Coolant: Ravenol HTC
Old Jul 22, 2018 | 09:57 AM
  #29
cosmomiller's Avatar
Top Answer: 1
Engine: Mobil 1 0W-30. 67K miles and the oil level never changes one iota. Every 3k miles. Engine inside looks brand new.
OEM Oil Filter. Has the double metal ring with gasket unlike any other filter I have seen. Ensures proper torque.
Transmission: Amsoil. Night and day between cold and warm.
Diff: Mobil 1 75W-90. Works for Billman, works for me.
Brakes: ATE SL6 fluid. Designed for ABS and VSA systems. Slightly lower boil point but I don’t track it.
Clutch: Good old Honda and frequently use the “blaster” (actually a Syringe) to change it out often.
Coolant. OEM. Never changed yet on my 2009.
Old Jul 22, 2018 | 02:12 PM
  #30
flanders's Avatar
Engine: Motul X-cess 5w-40
Brake/Clutch: Motul RBF600
Transmission: Honda MTF3
Diff: Castrol Syntrax Longlife 75W-90 & 75W-140 mixed 50/50
Coolant: Honda Type 2
Fuel: E85 with some Red Line Si-alcohol
DangerZone9K
Sep 16, 2012 04:58 PM
Sub_01
May 20, 2009 07:08 AM
Rev2-9K
Jun 24, 2002 04:41 PM
