S2000 won't start
Old 06-29-2013, 08:11 AM
USMC3140's Avatar
Default S2000 won't start
Okay, this is my first time posting here as I recently bought my first S2000 (a 2001) ...Today I was driving and the EPS light came on, so I shut the car off and when I went to turn it back on, it wouldn't start...I managed to push start it earlier and I drove it around for a while but when I parked at my apartment it again would not start...
when I push the start button there is an audible *click* in the engine bay...the battery is good, fuses are good...I thought perhaps it was the solenoid (maybe the ground, or hot wire came loose) however I don't know where that is located to check it...any advice would be much appreciated gents
Old 06-30-2013, 06:03 AM
USMC3140's Avatar
I determined the battery was good with a voltometer...and you were right that starter is not easy to get at, I finally got it, and the starter is getting power and not cranking at all...so I ordered a new one and that should fix her. Thank you hecash
OORAH
Old 06-30-2013, 08:46 AM
Billman250's Avatar
Received 1,316 Likes on 797 Posts
12v does not mean the battery is good.
I'd bank on bad battery or connection, a bad starter in this car has almost never been reported.
How do your headlights work?
I would turn the key on, headlights on, and wipers on, and fan on. They should all work nicely together.
Old 06-30-2013, 08:50 AM
USMC3140's Avatar
Thanks for the advice billman, I'll go double-check that when I get back home
$ur_Lance_uhlot
01-10-2012 06:41 AM
ajv85483
04-29-2010 11:30 AM
xtremesq
07-31-2008 09:48 AM
prorcracer87
16
09-15-2007 02:15 PM
pittpanther
06-24-2003 08:01 AM
Quick Reply: S2000 won't start
