SANDING HEADLIGHTS
Old Apr 12, 2006 | 03:59 PM
WyattH's Avatar
Default SANDING HEADLIGHTS
Hi guys...
Well, replacing the amber diffusers went array and now I need to wetsand my lenses.
They are taken apart and I will be doing both front and back of both lenses.
To those that have done it:
How did you do it? What grits did you use? Any tips?
Old Apr 13, 2006 | 05:49 AM
PilotSi's Avatar
I'd start off with 800. I would then move to 1200, 1400, 1800, 2000. After that, I would use an aluminum mag polish (Mother's has one). What you're trying to do each time is make the scratches from the sand paper, finer & finer. By the time you get to the metal polish, it should look like brand new again.
Good luck!
Edit: Oh yeah, the back won't need it. Only the front. You ARE getting a hazing problem right? Just the front will be fine.
Old Apr 13, 2006 | 07:38 AM
thetz99's Avatar
Sand paper seems to be extreme... If you have a porter cable, use your most agressive pad and plastic polish on the outside of the lens.
here are some before after pics and what I used.
https://www.s2ki.com/forums/index.php?showtopic=296109
Old Apr 13, 2006 | 10:24 AM
Incubus's Avatar
Array - a regular and imposing grouping or arrangement.
Awry - off the correct or expected course.
Old Apr 13, 2006 | 11:05 AM
IIGQ4U's Avatar
Lol, you guys are hilarious.
Would the sanding process be more difficult than a Porter Cable? I am in the same predicament ang have a lot of small scratches and indents from small rocks on my headlights and the headlights are not 100% clear.
orange_chicken
Jun 25, 2008 08:08 AM
Shannon
San Diego S2000 Owners
Jul 13, 2006 10:07 AM
rijowysock
Jun 18, 2006 02:10 PM
DVSwetwilly
Jul 27, 2004 02:55 PM
Albert
Jul 18, 2002 08:04 PM
