Second Gear is Grinding Bad
Old Oct 19, 2008 | 11:59 PM
CarbonYellowJ's's Avatar
Unhappy Second Gear is Grinding Bad
Well my second gear feels really funny. Gritty would be the best way of describing it. I plan on getting the tranny flushed to see if some debris is stuck in there. I was doing a burnout and when I went to shift into second I think I shifted before the clutch disengaged or the other way around. either way it made a horrible noise. Doing the burnouts with Advan Ao48's wasnt a great idea either. So my question is, if my second gear is damaged, is it cheaper to get the tranny repaired or just source a used AP2 tranny? Thanks in advance for the help!
Old Oct 20, 2008 | 07:38 AM
AngryTurtle's Avatar
I would like to point out before any one posts. That he is not complaining at all, just asking for advice.
Old Oct 20, 2008 | 11:16 AM
Mrfixit687's Avatar
It depends on how cheap you can get a used tranny. I'm guessing it will be cheaper to get the transmission rebuilt but more down time compared to replacing the tranny. Best bet is to call up some transmission shops and get pricequotes, and then see how much you can get a used tranny for.
Old Oct 20, 2008 | 12:19 PM
R3DS2K's Avatar
yea getting a used tranny would be less down time and than you can rebuild that 1st one so you will have a back up just incase you doing some funky burnouts .
Old Oct 20, 2008 | 02:16 PM
Ok Ill look into getting quotes. Luckily I have another car to use. Also Im going to rebuild the ORC clutch at the same and Ill need to source a rebuild kit from Japan anyways.
p0staboy
Apr 22, 2014 09:42 PM
paul2011s2000
Mar 11, 2012 09:44 AM
rosodigital
Feb 28, 2012 07:32 PM
IMSMEISTER
Mar 20, 2008 05:40 PM
559s2k
Jul 7, 2006 04:33 AM
