Setting timing with a timing light?
Old Oct 16, 2008 | 04:14 PM
Stratocaster's Avatar
Default Setting timing with a timing light?
OK, the service manual has a process to connect to the service loop (done) but there is a step that states "Jump the SCS line with the HDS"
Can anyone tell me how to do this without an HDS? (Honda Diag System)
I need to check the timing to poperly configure AEM EMS
Old Oct 16, 2008 | 05:33 PM
Slows2k's Avatar
Pin 9 (brown) on the DLC and ground. DLC Pin 4 (black) works for the ground.
If you've got the EMS plugged in I don't think It's going to have any effect though. The SCS forces the PCM to base timing at idle.
Old Oct 17, 2008 | 05:24 AM
Thanks, I will test it and see if that works to get the serivce loop to trigger the light.
TerminatioN
Aug 17, 2010 10:07 AM
dsddcd
Mar 14, 2009 12:29 PM
ZSAK
Jan 19, 2009 03:45 PM
QUICK_AG
Jul 31, 2007 04:35 PM
dragtek
Jul 14, 2007 04:48 PM
