Since were on the topic of clutch fluid...
Originally Posted by Hockey,Dec 27 2005, 09:32 AM
You do NOT need a second person to bleed the clutch (or brakes for that matter). Thanks to a very seasoned race shop owner in San Diego, I learned of an effective and inexpensive technique. Since I ran a one-man mobile service operation and did a number of these type jobs I needed a viable solution. Here is what he suggested......
-Hockey
-Hockey
The one-person bleed worked flawlessly! I looped the tubing upwards, and not a single bubble entered the bleeder. Would have taken less than 10 mins, however, when I completed the bleed (after the cdv removal) I found a washer that I forgot to attach to the banjo. Took off the banjo, inserted washer...bleed again. Did three cycles, filled reservoir, close cap, close bleeder...5min later all done!
You get two
I appreciated your advise!!
Gary
Awesome. I had something like this in mind where I tried to to keep an upside down 'U' kink in the tube to keep the air bubbles up... but it wouldn't stay. I will try the loop with some sort of magnet holder or something..
Last time I flushed the clutch fluid myself I ended up alternating going under the car, in the footwell for about 20 times. I was quite sore the next day.
