Slight "Click" at Launch
Old Sep 9, 2005 | 11:05 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
36MM, or 1 7/16 works great also. You'll also need a punch shaped to un-stake the nut, and another blunt chisel to re-stake it.
As of now, I've got two guys who may have bad bearings from leaving it unattended. We'll see how it goes after Saturday.
Old Sep 9, 2005 | 11:08 AM
Project SSAP1's Avatar
i might be the 3rd..cause this clicking has been going on for months :-(
Old Sep 9, 2005 | 11:13 AM
Jasonoff's Avatar
Banned
Don't use the helms. It was 180ft/lb but now it's 220ft/lb.
Old Sep 9, 2005 | 06:59 PM
SolReborn's Avatar
This may be a stupid question, but where is the axle nut? What does it look like?
I have this same clicking noise when starting to move, too.
Old Sep 9, 2005 | 09:47 PM
mxt_77's Avatar
OT: Could this same symptom be seen/heard in a 95 Accord (from the front wheels, obviously)? I've got a click as I let my clutch out, but I was thinking it was something with the clutch or tranny, because it doesn't just occur when I first start out, it does it pretty much any time I let the clutch out. Plus, I have some hella bad clutch chatter sometimes (though the clutch never slips).
Factory clutch, 172K miles. Used to be my parents' car... they said the chatter has occurred as long as they can remember. Never asked 'em about the click, because I assumed it's related.
Old Sep 9, 2005 | 09:49 PM
mxt_77's Avatar
Great picture of it here (as well as the procedure for loosening/tightening it). It's referred to as the spindle nut in that thread.
https://www.s2ki.com/forums/index.php?showtopic=223599
Old Sep 10, 2005 | 09:18 AM
Billman250's Avatar
Top Answer: 1
Update....the bearing is ok, but the hub is shot. Leaving the nut loose for a prolonged time has allowed the inner bearing race to spin on the hub. The hub has worn down about .008 and the once press fit race is now sloping around on the hub.
I'd urge all s2k owners to tend to the alxe nuts now
Old Jul 24, 2006 | 09:24 PM
Beaver's Avatar
Do you know the TSB # for this?
Old Jul 24, 2006 | 11:38 PM
Hockey's Avatar
Scroll down to VFROOOMs post.
Click Me
You'll probably have to print it out to read it better. Heres more....
It isn't a TSB, but something less official called a Technical Service Note, #011201, the page image VFROOOM posted above.
-Hockey
WarrenW
Jun 10, 2018 01:34 AM
S2Kid91
Jul 20, 2013 04:46 AM
954chris
Mar 27, 2013 02:06 AM
Jack_in_the_Box
May 6, 2008 02:34 AM
ccs2000
Jun 3, 2007 10:05 AM
