Is this sound normal?
Old Nov 23, 2003 | 11:08 PM
ThaWyze1's Avatar
Default Is this sound normal?
I've only had my car for a few weeks and haven't VTEC'ed it too much, but the last few times that I did, I noticed that there's a hissing noise when I get into VTEC....
Is this normal? Does it happen to anyone else? It would give me great peace of mind if someone knew what this was.
Thanks in advance.
Old Nov 24, 2003 | 12:53 AM
cthree's Avatar
Administrator
Well, first, is it a new car? If no, does it have an aftermarket airbox/CAI? Your post shows a 00 model which I assume to be used if you've only have it a few weeks.
The hissing is the air intake. I personally didn't notice it with the stock air intake and filter box but it is certainly noticable with my Injen CAI, even at idle. Your little engine is consuming vast quantities of air esp. at high RPMs.
Old Nov 24, 2003 | 01:08 AM
tritium_pie's Avatar
^ omg. cthree posted something that isn't a sticky note?! what are u doin down here in the trenches with us lurkers n whores?
Old Nov 24, 2003 | 01:15 AM
(so as not to whore-up this thread) if you don't hear the noise during normal driving, but only when your motor crosses over into VTEC, then it has to be intake related. the only thing that changes is the cams shift over to the more agressive profiles and the motor sucks in more air. well, also the corners of your mouth start approaching your ears. so either you're sucking in air between your grinning teeth, or it's your intake is hissing.
you might just check the air filter to make sure it's clean and seated properly.
Old Nov 24, 2003 | 08:19 AM
ThaWyze1's Avatar
LOL tritium_pie! That's as good a reason as I've ever heard! But on a serious note, thanks for the advice, I'll go check and see if the air filter is clean.
cthree - Yes, it's a used S2K and has a stock intake. I didn't think a stock intake made that kind of hissing, but of course I've never owned a car like an S2K before. Has anyone else with a stock intake heard this sound?
Wazio7
Jun 7, 2017 06:18 AM
jonomo
Oct 17, 2006 11:28 AM
jimpom23
Jul 31, 2005 12:50 PM
Hondo
Mar 14, 2004 07:06 PM
Lovetodrive2000
Jul 14, 2002 11:21 PM
