Spoon header
Old Dec 14, 2001 | 01:20 PM
BAD S2K's Avatar
Default Spoon header
Just finished installing the spoon header and drove about 7-8 miles. Maybe it's me but I don't feel a difference. Any ideas?
Old Dec 14, 2001 | 01:31 PM
Cyber Logic's Avatar
Well first off...I think you can expect somewhere around 5-10 hp for that mod and that's still pretty hard to detect on the but dyno...expecially if the power was gained in midrange...
Also...I think this is debatable...but try resetting your ecu and letting the computer relearn the fuel settings with the new header...I don't know just an idea.
Old Dec 14, 2001 | 01:41 PM
cdelena's Avatar
Some header comments here..
https://www.s2ki.com/forums/showthread.php?...hlight=midrange
Old Dec 14, 2001 | 02:02 PM
BAD S2K's Avatar
I've heard several posters say that the s2k ECU is not a learning ECU. Is that true? If not; how do you reset it?
Old Dec 14, 2001 | 02:21 PM
Pappy's Avatar
The easy way to reset the ECU is to disconnect the Negative Terminal of the battery for about 5 min. Then just put it back on the battery and drive off. I heard it takes anywhere from 100 to 300 miles for the ECU to adjust.
Old Dec 14, 2001 | 03:32 PM
BAD S2K's Avatar
Thanks Pappy. Still enjoying the heatshield!
Old Dec 14, 2001 | 11:27 PM
Pappy's Avatar
Very glad to hear that! Tell me how the header feels after reset of ECU?
Hope everything works out....
Old Dec 15, 2001 | 03:56 AM
BAD S2K's Avatar
I decided at this time not to reset the ECU. I did notice two things on my way to work this morning. These things may be just in my head; but, I swear things have changed.
1st- I have the RM Racing cat-back exhaust and w/ the top up the cabin resonates badly at some speeds and when the throttle is lifted at certain RPMs. This has gone away since installing the header.
2nd- I V-TEC'd 4-5 times on my 30 mile trip to work and the abrupt transition has gone. The car pulls every bit has hard as it did pre-header install; but, the v-tec kick isn't as pronounced as it used to be.
Any ideas on my 2 initial findings?
Old Dec 15, 2001 | 08:25 AM
mingster's Avatar
[QUOTE]Originally posted by BAD S2K
[B]I decided at this time not to reset the ECU. I did notice two things on my way to work this morning. These things may be just in my head; but, I swear things have changed.
kaissi
Sep 25, 2010 06:11 AM
gianni.69
Feb 18, 2010 03:27 PM
s2konroids
Aug 20, 2008 05:17 PM
zerospel
Dec 11, 2006 09:29 AM
vin02s2k
Aug 8, 2002 07:06 PM
